Final Cut Pro 7 - One audio track
Emily Geraghty
on Aug 6, 2013 at 2:28:02 am
This is probably a goofy question, new to final cut - but I just edited my entire project and realized that my mono audio is only on track A1, and I want it to play on tracks A1 and A2. The tracks are linked - is there an easy way to get it to play on tracks A1 and A2 or am I screwed? Hope that makes sense. Thanks :)
Joe Barta IV
Re: Final Cut Pro 7 - One audio track
on Aug 6, 2013 at 1:06:57 pm
Are the levels on the audio meter showing audio on L and R? If so, then your audio will output equally on tracks 1 and 2 when exporting.
Bars & Tone
SALUTE!
Simon Modery
on Aug 6, 2013 at 1:10:37 pm
You mean, you only have a signal in A1 and A2 is silent? And that results in the audio only coming out of the left channel? Am I guessing right so far?
Double click on the audio clip so it opens in the viewer. There, set the Pan-slider to centre. Now the sound from A1 should come out of the left and the right channel.
Head of Postproduction
Motherlode
http://www.simonmodery.com
Mark Suszko
on Aug 6, 2013 at 1:53:59 pm
Copy-pasting a duplicate audio track to track 2 can be problematic: it can introduce problems like phase cancellation. Check the single track for center-pan first.
Kelly Black
on Feb 10, 2016 at 4:56:07 pm
Ahhhh Thank you!!!! I've been trying to figure this out for like an hour!!
