Audio-Levels, Relative and Absolute
Alexander Kallas
on Aug 5, 2013 at 11:14:36 pm
Hi all,
I cannot get this to work after rubber-banding the audio in FCP7. The audio line reverts to straight line
after applying the levels modifier. Frustrating, Kevin McAuliffe's article does not seem to apply!
Cheers
Alexander
Rafael Amador
Re: Audio-Levels, Relative and Absolute
on Aug 6, 2013 at 1:12:52 am
What's the problem Alex?
If you have already animated (key-frames) or adjusted your audio, you have to check RELATIVE, in order to keep that animation.
If you chose ABSOLUTE, the whole audio will be set at the absolute value you have set.
rafael
Alexander Kallas
on Aug 6, 2013 at 1:56:23 am
Thanks Raf,
I want to adjust all the separate clips in the sequence simultaneously.
Each clip has been rubber-banded to a greater or lessor extent.
Cheers
Alexander
Dave LaRonde
on Aug 6, 2013 at 4:36:54 am
There's a master fader, y'know...
Dave LaRonde
Former Sr. Promotion Producer
Rafael Amador
on Aug 6, 2013 at 6:22:16 am
[Alexander Kallas] "I want to adjust all the separate clips in the sequence simultaneously.
Each clip has been rubber-banded to a greater or lessor extent."
Then select the whole tracks and apply the RELATIVE gain option.
The rubber banding will be kept and gain will be added or reduced up to the value you set
rafael
Alexander Kallas
on Aug 7, 2013 at 5:21:17 am
Got it now, thanks Rafael
Cheers
Alexander
