Audio synch problems. FCP7, Canon 6D, Zoom H1.
mike bartleyy
on Aug 5, 2013 at 5:22:19 pm
I'm having audio synching issues in FCP7.
External audio (from Zoom H1) imported to FCP. as a .wav 48khz.
Imported 6D footage 25(and 24) fps that has been through compressor and is now ProRes 442. (assume 6D is 48khz audio by default???)
FCP is set up as 48khz yet I cannot synch the .wav with the 6D footage audio. It seems to be one frame out and the audio waves are also a frame out with the actual audio.
I have tried resetting FCP and deleting user settings. Also tried 25 and 24 fps.
Can anyone suggest a fix?
Many thanks.
Sascha Engel
Re: Audio synch problems. FCP7, Canon 6D, Zoom H1.
on Sep 20, 2013 at 6:11:27 pm
How you converted o ProRes? Compressor? You left the audio set to Pass-through?
Sascha Engel
TIME BANDITZ Productions
http://www.youtube.com/taikang
