23.98 to 29.97p - Interpolating to 29.97 progressive?
Aj Koch
on Aug 2, 2013 at 9:20:27 am
Hi! Quick question for you frame rate guys out there...
This weekend I'm shooting and editing a 1920x1080 project at 23.98fps. End client requests final delivery be at 29.97 or 30 progressive. It is also my understanding that, after delivery, the client may be creating a down-converted SD DVD on THEIR end.
Normally when editing 23.98 for delivery @ 29.97 for broadcast, I'll edit the entire thing at 23.98, then let Final Cut do its interpolation on a final 23.98 QT in a 29.97i/upper field sequence, and export the final 29.97i QT from there.
But since the client is asking for 29.97p, would anyone forsee any issues doing an "interpolation" from 23.98 to 29.97p? Obviously every 4th progressive frame would be doubled instead of being broken up into fields, but is that, on a technical level, "taboo?" Would there be any later issues if they did a software-based downconvert to SD lower field for DVD purposes?
Any advice would be appreciated.
Thanks in advance.
-Aj
Rafael Amador
Re: 23.98 to 29.97p - Interpolating to 29.97 progressive?
on Aug 2, 2013 at 9:30:44 am
Picture will look smoother if you add a proper pull-down, but no taboo for repeating frames or interpolating full frames.
[Aj Koch] " Would there be any later issues if they did a software-based downconvert to SD lower field for DVD purposes?"
Why don't just make a 23,98fps DVD?
The player will add the pull down on playing.
BTW, if you make it 29,97fps, no need to make it LOWER FIRST.
MPEG-2 DVD compliant can be Upper or Lower first.
If your source is Upper first keep it like that. No need for shifting fields.
rafael
Aj Koch
on Aug 2, 2013 at 5:35:50 pm
Awesome, good info to know! Thanks Rafael!
Dave LaRonde
on Aug 2, 2013 at 4:44:42 pm
If you have to DELIVER 29.97 -- and progressive, to make it even worse -- why on Earth would you want to shoot at 23.976, which is just about the worst frame rate you could pick?
Why not just shoot 30P and completely eliminate any frame rate headaches?
But who am I to be a frame rate critic? If you really like jumping through expensive or time-consuming frame rate conversion hoops when you don't have to, knock yourself out.
Dave LaRonde
Former Sr. Promotion Producer
Aj Koch
on Aug 2, 2013 at 5:41:43 pm
Shooting 30P was discussed, but the client prefers the look of 23.98.
I ran a pulldown test going from 23.98 to 29.97P last night in Final Cut, and seems to work fine, as Rafael suggested. It's arguably not as smooth as interpolating to 29.97i, but it's still relatively smooth, and I think the difference is negligible for this project. Final Cut does the pulldown pretty quick, so time spent doing the conversion is minimal.
But I definitely appreciate the opinion!
-Aj
Dave LaRonde
on Aug 2, 2013 at 6:42:49 pm
Sorry to hear that. You'll want to do this at a post house with hardware. It will give you your best chance to meet two incompatible frame rates.
And it will be expensive: hope you have the budget for it!
Dave LaRonde
John Pale
on Aug 2, 2013 at 10:21:56 pm
DVD Players automatically add the proper pulldown.
Pretty much all "Hollywood" DVDs are 23.98, and will play that way via HDMI. The analog outputs will have pulldown added.
Its really a non-issue.
Rich Rubasch
on Aug 6, 2013 at 9:20:21 pm
If we know a project will go to YouTube and DVD and especially a possible PAL delivery we will shoot 23.976 as long as we aren't mixing our footage with any 29.97 clips.
Also purely animations are sometimes done in 23.976 to reduce frames needed to render.
We use Episode to convert 23.976 to 29.97p as it has great control over the output and we have made great looking pulldowns without hardware.
There are reasons, but if we go to broadcast as a primary delivery I usually recommend 29.97p (30p)
Rich Rubasch
Tilt Media Inc.
Video Production, Post, Studio Sound Stage
Founder/President/Editor/Designer/Animator
http://www.tiltmedia.com
