End Credits - creating problems in DVD Player
Sridhar Kumar
on Jul 31, 2013 at 8:38:11 pm
I edited my 20 minutes short film in FCP. Subtitles are also created in FCP. For end credits, I used Adobe After Effects, exported as a mov file and imported that file into FCP. I designed my DVD in DVD SP. I tested the DVD before burning and everything looked good including the end credits. Then I burned the DVD and tested in DVD player. That's when I came across this problem.
Subtitles came out fine but the end credits that I created from AE is slightly blurry. I don't where the problem is. I am assuming it might be the frame rate.
My film in FCP is 24 fps. So when I exported the end credits file from AE, I used the same frame rate 24 fps. I used the Compressor 'Create DVD' template. This automatically set the frame rate to 23.98 (Inspector - Video Format - Frame Rate). I tried to change to 24 but the field is grayed out.
When I imported the compressed ac3 and m2v files to DVDSP, I noticed that MPEG-2 Video frame rate is displaying as 29.97 fps. As I did not change the frame rate myself in Compressor/DVDSP, I did not give that much importance.
I burned the DVD and tested in MAC which played fine. The problem occurred when I played in DVD player. Where is the problem and how do I fix this?
PS: 1) The end credits I have is not a scrolling credit. Static credits fading in and fading out.
2) I used the font 'Trajan Pro' in AE to create end credits. Can the blurry be due to this font type?
Thanks.
Rafael Amador
Re: End Credits - creating problems in DVD Player
on Aug 1, 2013 at 9:12:39 am
[Sridhar Kumar] "My film in FCP is 24 fps."
Film cameras makes real 24fps.
Video cameras make 23,98 fps which is normally called p24.
24 fps is not a standard in video and so, DVDs are 23,98 (or 29,97).
You must make your AE credits at 23,98fps.
rafael
Sridhar Kumar
on Aug 1, 2013 at 10:07:23 pm
I exported the credits in 23.976 frame rate from AE. Still it creates the same problem when I play it in the DVD player.
I also tried exporting in 29.97 frame rate. Same problem.
Even in small indie movies, I have seen clean credits without any blurry. Any one any suggestions?
Rafael Amador
on Aug 2, 2013 at 1:56:19 pm
Which codec are you using?
rafael
Sridhar Kumar
on Aug 2, 2013 at 10:50:11 pm
In FCP,
Video settings is Apple ProRes 422 (HQ).
In Compressor,
Video codec is MPEG-2.
Video encoder format is M2V.
Audio encoder format is AC3.
Other information regarding the Video in Compressor:
Name: DVD MPEG-2 Video, High quality Description: Maximize bit rate for duration of source File Extension: m2v Estimated size: 3.52 GB/hour of source Type: MPEG-2 video elementary stream
Usage:SD DVD Video Encoder
Format: M2V Width and Height: Automatic
Selected: 720 x 480 Pixel aspect ratio: NTSC CCIR 601/DV (16:9) Crop: None Padding: None Frame rate: (100% of source)
Selected: 23.976 Frame Controls Automatically selected:
Retiming: (Fast) Nearest Frame Resize Filter: Linear Filter Deinterlace Filter: Fast (Line Averaging) Adaptive Details: On
Antialias: 0 Detail Level: 0 Field Output: Same as Source
Start timecode from source Aspect ratio: Automatic
Selected 16:9 Field dominance: Automatic:
Selected Progressive Average bit rate automatic,
selected: 7.826087 (Mbps) 2 Pass VBR enabled
Maximum bit rate: 9 (Mbps) High quality
Better motion estimation Closed GOP Size: 15, Structure: IBBP DVD Studio Pro meta-data enabled
