Export ProresHQ with 5.1 and 2tr audio
Brian Schoklant
on Jul 30, 2013 at 3:27:11 pm
Hi all,
I'm asked to export a ProResHQ with 5.1 and 2tr audio embedded. I have the all the separate tracks as 24 bit 48khz wave files, and of course the film (in ProResHQ, a.o.).
How do I go about that from here? What should I keep in mind? On what tracks go the required tracks (Lt - Rt for stereo,
L - C - R - Ls - Rs - LFE for the 5.1 mix) and what sequence settings should do I use?
Thank you for your time!
Brian.
Brian Schoklant
Re: Export ProresHQ with 5.1 and 2tr audio
on Jul 30, 2013 at 8:57:39 pm
I found an answer by searching a bit harder:
http://cdn.indieflix.com.s3.amazonaws.com/films/flatpages/exportingsurround...
Basically the same as putting it to tape. Who would have thought ;)
