exporting a 23.98PsF QT file from FCP
Michael edmunds
on Jul 29, 2013 at 3:37:05 pm
So I know this is not new information and I have searched this forum with no luck so I'm hoping to find out by directly asking. I am delivering a finished QT with the following specs "Apple ProRes HQ 1920x1080psf, 23.98fps,4:2:2 original aspect ratio". So all footage was shot on a 5D(1920x1080, 23.98) and converted to ProRes 422 for editing. I have no experience delivering a psf file and don't know how to do so? So my question is how do I create this file without using hardware? I know this is usually done through hardware when outputting to tape, but can it be done through software? Any help would be great!
Shane Ross
Re: exporting a 23.98PsF QT file from FCP
on Jul 29, 2013 at 4:12:56 pm
Just change your sequence compressor to ProRes HQ...re-render. Then export a self contained QT file. Everything is already 23.98....done.
Shane
Little Frog Post
Mark Spano
on Aug 1, 2013 at 5:37:28 pm
What Shane says is correct, and you should follow his instructions.
To elaborate on the other part of your question: there is no such thing as PsF in file formats. PsF is only created upon output over SDI. The spec sheet is wrong or has a typo. A ProRes HQ file at 23.976 fps will ALWAYS be P, not PsF. In the file based world, progressive frames have no reason to be segmented.
