Trouble installing FCS3 onto Mountain Lion
David Cimbol
on Jul 21, 2013 at 7:57:03 pm
My son just bought a new MacBook Pro 2.3gHz with mountain lion 10.8.4 installed. He needed FCP7 and found the least expensive route was fcs3. When we attempt to install it, we get the error "the installation failed. the installer could not install the software. the installer could not install the software because there was no software found to install". I have read people saying that FCS will and and some say will not work with mountain lion.
Any help would be greatly appreciated. Thanks
David Eaks
Re: Trouble installing FCS3 onto Mountain Lion
on Jul 21, 2013 at 8:26:49 pm
It works. Are you installing from official FCS discs? Is it possible that you accidentally purchased a boot leg copy? Or are you installing from disc images that are saved to an external drive? FCPX won't do?
David Cimbol
on Jul 21, 2013 at 10:14:05 pm
It is the full academic version. Not sure that has anything to do with it. My son said fcp7 is better control than fcpx. I am not a video guy so do not know. Could it be that the person we purchased it from never uninstalled it or would that have nothing to do with it?
David Eaks
on Jul 21, 2013 at 11:15:07 pm
Just making sure you didn't get ripped off. I haven't seen the "because there is no software to install" warning before. I remember people having problems in the past (like Snow Leopard days) who were able to install each FCS app one at a time, but not all at once. Maybe give that a try. I keep a Disc image of each install disc saved on a hard drive. Installation time goes from 4 hours down to 40 minutes or less depending on content chosen to install.
If the previous owner didn't uninstall, you would get a warning if you tried to open FCP while the previous owner had it running as well, and you are both connected to the Internet.
Your son is aware that the Academic version is only for learning the program, and it is not legal to be used for "work"? I'd advise that he look closer at FCPX, FCP7 doesn't have a terribly good grasp on life or the future. Not to say FCP7 doesn't work or isn't a good program, its just, dead. FCPX is actually very good, despite its poorly received release.
David Cimbol
on Jul 22, 2013 at 6:57:18 pm
I am hoping I did not get ripped off as well. I attempted to install one module at a time and received the same error. My son is going into his freshman year of college and will be using it for educational purposes only. He had checked with the college and they are using FCP7 and that is one reason he wanted it. He also had used it extensively in his high school tv classes.
Are there any tricks to install programs that do not want to install? Like a force install? or starting the computer is a "safe" mode. perhaps there is a software installed that is not allowing FCS3 to be installed?
David Cimbol
on Jul 22, 2013 at 7:50:35 pm
I copied the log. Maybe this can lend some information as to whether the computer or installer are not working properly:
7/22/13 3:46:37.270 PM Dock[162]: no information back from LS about running process
7/22/13 3:46:40.199 PM Installer[565]: CoreAnimation: warning, deleted thread with uncommitted CATransaction; set CA_DEBUG_TRANSACTIONS=1 in environment to log backtraces.
7/22/13 3:46:40.732 PM WindowServer[92]: Received display connect changed for display 0x4272900
7/22/13 3:46:40.759 PM WindowServer[92]: Received display connect changed for display 0x3f003d
7/22/13 3:46:40.759 PM WindowServer[92]: Received display connect changed for display 0x3f003e
7/22/13 3:46:40.759 PM WindowServer[92]: Received display connect changed for display 0x3f003f
7/22/13 3:46:40.761 PM WindowServer[92]: CGXMuxAcknowledge: Posting glitchless acknowledge
7/22/13 3:46:40.774 PM WindowServer[92]: MPAccessSurfaceForDisplayDevice: Set up page flip mode on display 0x04272900 device: 0x1024afa10 isBackBuffered: 1 numComp: 3 numDisp: 3
7/22/13 3:46:40.802 PM WindowServer[92]: Received display connect changed for display 0x4272900
7/22/13 3:46:41.377 PM WindowServer[92]: Received display connect changed for display 0x4272900
7/22/13 3:46:41.408 PM WindowServer[92]: CGXMuxAcknowledge: Posting glitchless acknowledge
7/22/13 3:46:41.417 PM WindowServer[92]: MPAccessSurfaceForDisplayDevice: Set up page flip mode on display 0x04272900 device: 0x1024afa10 isBackBuffered: 1 numComp: 3 numDisp: 3
7/22/13 3:46:41.429 PM WindowServer[92]: Received display connect changed for display 0x4272900
7/22/13 3:46:41.444 PM WindowServer[92]: Received display connect changed for display 0x3f003d
7/22/13 3:46:41.444 PM WindowServer[92]: Received display connect changed for display 0x3f003e
7/22/13 3:46:41.445 PM WindowServer[92]: Received display connect changed for display 0x3f003f
7/22/13 3:46:42.401 PM Installer[565]: CoreAnimation: warning, deleted thread with uncommitted CATransaction; set CA_DEBUG_TRANSACTIONS=1 in environment to log backtraces.
7/22/13 3:46:45.230 PM Installer[565]: *** WARNING: -[NSImage compositeToPoint:operation:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
7/22/13 3:46:45.230 PM Installer[565]: *** WARNING: -[NSImage compositeToPoint:fromRect:operation:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
7/22/13 3:46:45.244 PM Installer[565]: *** WARNING: -[NSImage compositeToPoint:operation:fraction:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
7/22/13 3:46:45.244 PM Installer[565]: *** WARNING: -[NSImage compositeToPoint:fromRect:operation:fraction:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
7/22/13 3:46:47.740 PM Installer[565]: CoreAnimation: warning, deleted thread with uncommitted CATransaction; set CA_DEBUG_TRANSACTIONS=1 in environment to log backtraces.
7/22/13 3:46:48.640 PM Installer[565]: Error loading /System/Library/CoreServices/InstallerStatusNotifications.bundle/Contents/MacOS/InstallerStatusNotifications: dlopen(/System/Library/CoreServices/InstallerStatusNotifications.bundle/Contents/MacOS/InstallerStatusNotifications, 265): no suitable image found. Did find:
/System/Library/CoreServices/InstallerStatusNotifications.bundle/Contents/MacOS/InstallerStatusNotifications: mach-o, but wrong architecture
7/22/13 3:47:04.551 PM coreservicesd[63]: Application App:"Installer" [ 0x0/0x5c05c] @ 0x0x7f9ef2c070d0 tried to be brought forward, but isn't in fPermittedFrontASNs ( ( ASN:0x0-0x5d05d:) ), so denying.
7/22/13 3:47:04.551 PM WindowServer[92]: [cps/setfront] Failed setting the front application to Installer, psn 0x0-0x5c05c, securitySessionID=0x186a4, err=-13066
7/22/13 3:47:06.000 PM kernel[0]: SAM Multimedia: READ or WRITE failed, SENSE_KEY = 0x03, ASC = 0x11, ASCQ = 0x00
7/22/13 3:47:07.000 PM kernel[0]: SAM Multimedia: READ or WRITE failed, SENSE_KEY = 0x03, ASC = 0x11, ASCQ = 0x00
7/22/13 3:47:07.000 PM kernel[0]: disk1s3: I/O error.
7/22/13 3:47:07.466 PM Installer[565]: Package /Volumes/Final Cut Studio Install/Installer/Packages/Qmaster.pkg uses a deprecated pre-10.2 format (or uses a newer format but is invalid).
7/22/13 3:47:09.000 PM kernel[0]: SAM Multimedia: READ or WRITE failed, SENSE_KEY = 0x03, ASC = 0x11, ASCQ = 0x00
7/22/13 3:47:10.000 PM kernel[0]: SAM Multimedia: READ or WRITE failed, SENSE_KEY = 0x03, ASC = 0x11, ASCQ = 0x00
7/22/13 3:47:10.000 PM kernel[0]: disk1s3: I/O error.
7/22/13 3:47:10.073 PM Installer[565]: CoreAnimation: warning, deleted thread with uncommitted CATransaction; set CA_DEBUG_TRANSACTIONS=1 in environment to log backtraces.
7/22/13 3:47:10.230 PM Installer[565]: The Installer could not install the software because there was no software found to install.
Tom Matthies
on Jul 23, 2013 at 1:52:40 pm
Just a shot in the dark. How many physical disks do you have? Are they the Apple originals? Are you sure that this is FCP Studio3 you are trying to install and not FCP3, the older, non-studio version? I don't think FCP3 will run on an Intel based machine. Just a thought...
E=MC2+/-2db
David Cimbol
on Jul 25, 2013 at 1:07:44 pm
There are 7 disks including the install and content disks and are all original apple. I did verify that it is final cut studio 3. I think I am going to bring it into the apple store and see if some of the techs there could determine the issue. Not sure they will look at it being it is an older program.
David Cimbol
on Jul 27, 2013 at 10:28:28 am
I called applecare hoping that they will sincethe computer was recently purchased. They thinkthat the install disk is damagedand is sending a new one. Will let you know if that was the issue. Thanks for all of your help
