23.98 or 24p?
Steven Austin
23.98 or 24p?
on Jul 21, 2013 at 4:38:39 am
I'm going to be editing a low budget feature which already started shooting. Their first three days, the DP set his Canon C300 to 24p.
However everything I've ever cut has been in 23.98 or 29.97. This is a DTV feature which might be projected at festivals.
The DP is asking whether he should switch to 23.98 on Monday or stay at 24. I don't know how to advise him. Comments? Thanks!
P.S. has anyone used the free Canon plug-in for log & transfer? Or is there a third party software I should get?
Ryan Holmes
Re: 23.98 or 24p?
on Jul 22, 2013 at 1:36:44 am
Do you need to match back to already shot film? Then 24p is your answer.
If you're shooting this and expect to lay back to film then 24p is also problably your answer.
If you're shooting and expect to make digital copies then I'd stay as far away from 24p as possible. 23.98 is what you need.
From Canon's best practices PDF, page 7 ( http://www.learn.usa.canon.com/app/pdfs/white_papers/EOS_C300_Best_Practice... ):
EOS C300 cameras allow users to choose two frame rates that at first glance appear to be “24P”.
For conventional digital video recording at “24P”, users normally want to actually be shooting
at 23.976 fps. However, for video recording which must be precisely tied to existing 24.00 fps film footage, there’s a completely separate fps setting.
It cannot be over-emphasized — the 24.00P setting is NOT for general-purpose video
recording. DO NOT set 24.00P unless you deliberately intend to match video files with existing film footage which was shot at 24 fps in a film camera, or unless postproduction staff have specifically instructed camera operators to use this setting instead of 23.976P.
So unless you need true 24 for a specific reason I'd steer towards 23.98 as that is the standard.
Ryan Holmes
http://www.ryanholmes.me
@CutColorPost
Steven Austin
Re: 23.98 or 24p?
on Jul 22, 2013 at 5:32:57 am
Thanks for your reply! I will pass it on to the DP. I guess I'll just have to open up the 24p footage in a timeline that is set for 23.98, and deal with the results.
"In modern action films, the only people who work up a sweat are the editors." -- Roger Ebert
Steven Austin
Re: 23.98 or 24p?
on Jul 22, 2013 at 5:34:30 am
BTW, to answer your question... This show is going direct to DVD and will stay there. Digital projection for festivals. No film out whatsoever. Thx
Ryan Holmes
Re: 23.98 or 24p?
on Jul 22, 2013 at 1:51:56 pm
You may want to adjust your 24p footage then by running it through Compressor and making it true 23.976 footage. FCP can do mixed frame rate timelines, but it sometimes hiccups and causes headaches. Or if you plan on going out to other apps (Color, After Effects, Resolve, Smoke, etc.) they may not all be equally capable of handling a mixed frame rate timeline.
I'd take the hit now and adjust your 24p footage. Otherwise, it might come back to bite you in the end.
Just my $.02
Ryan Holmes
@CutColorPost
Steven Austin
Re: 23.98 or 24p?
on Jul 22, 2013 at 3:44:01 pm
Sounds right. 23.98 it is. Thx
