FCPX won't playback in any viewers, unless playing from the timeline.
Mark Mangan
on Jul 16, 2013 at 1:59:34 pm
Playback only works from the timelines, so I have to drop every clip there in order to play it. It's been an issue across several versions now and is driving me mental.
Any clip in the event selected will not play, JKL, spacebar, play button etc all play for about a frame and then stop. Video and audio skimming/scrubbing work fine, but it won't play the clip unless I drop it down to the timeline.
At least one other person has had the same issue. They came up with some kind of glitch workaround by resetting the window layout. I tried it and it worked for about a day but the issue came back and I can't get that workaround to work again.
https://discussions.apple.com/thread/4934887?start=0&tstart=0
I figured it would be worth asking around here to see if anyone has encountered the problem or has any ideas on fixing the issue?
Any help would be greatly appreciated. Thanks guys.
I'm working on a 17 inch MacBook Pro, 2.2ghz i7, OSX 10.7.5. FCPX 10.0.8. I'm using minidisplay port converter to HDMI for an external monitor.
