4 channel audio from DVCPRO deck
Alex Bayer
on Jul 9, 2013 at 4:10:28 pm
I am capturing a DVCPRO tape with 4 audio channels, but FCP will only let me capture 2 audio channels at a time. The manual says that you need to make 2 passes at capturing to get all 4 audio tracks. Is there a way to get all 4 at once? Using a Panasonic Dvcpro50 Deck. Thanks!
Shane Ross
Re: 4 channel audio from DVCPRO deck
on Jul 9, 2013 at 4:33:45 pm
The manufacturer of the deck says that you can only do 2 channels at a time. I'd believe them. That was an issue for a LONG time with that deck, that really made us angry. Panasonic cameras recorded 4 channels, but their decks only output TWO? They did come out with a more expensive deck not long after, that did 4. It's too long ago for me to recall what it was.
Shane
Little Frog Post
Alex Bayer
on Jul 9, 2013 at 4:53:06 pm
Thanks for the response Shane. -Alex
