Erasing clips from FCP
Karl Bergvall
on Jun 28, 2013 at 9:30:39 am
Is there a way to erase the clips from FCP without having to go to the finder ?
Rafael Amador
Re: Erasing clips from FCP
on Jun 28, 2013 at 3:04:43 pm
You mean erase a clip from your computer from inside FC?
No. Thanks God is a "no destructive" application.
The only change you can do to a clip from inside FC is on the TC.
rafael
Shane Ross
on Jun 28, 2013 at 5:40:09 pm
Actually...yes. Highlight the clips in the Browser, go to the MODIFY menu and choose MAKE OFFLINE, or press SHIFT-D. You'll be presented with options. Choose the one you want.
Shane
Little Frog Post
Rafael Amador
on Jun 29, 2013 at 3:12:01 am
[Shane Ross] "Actually...yes. Highlight the clips in the Browser, go to the MODIFY menu and choose MAKE OFFLINE, or press SHIFT-D. You'll be presented with options. Choose the one you want."
Hi Shane,
Will that erase the clip from the HD?
rafael
Shane Ross
on Jun 29, 2013 at 9:26:49 am
If you choose that option. You are presented with three options. Just to unlink the clip from the media file, to move the file to the trash and unlink, or to delete the file from the drive.
Shane
Little Frog Post
Rafael Amador
on Jun 29, 2013 at 11:15:33 am
Thanks for the info, Shane.
The truth is that I've never explored the "modify" options.
rafael
