Using Digital tools with FCp makes white dots across screen?
Eve Myhill
on Jun 26, 2013 at 5:19:07 pm
I have had an editor working on a project and he just sent over the project for me to export at my end. everything reconnected and worked fine except that all the shots that are using the silver/gold reflector are covered in a grid of white dots? any thoughts? Is this a watermark or a light source indicator that I can turn off?
I've attached an image to explain
Thanks in advance!
Shane Ross
Re: Using Digital tools with FCp makes white dots across screen?
on Jun 26, 2013 at 5:23:12 pm
It's a watermark. Unless you have that plugin on your system and licensed, those will appear.
You need to buy that plugin.
Shane
Little Frog Post
Eve Myhill
on Jun 27, 2013 at 9:02:09 am
Doh!. Purchased, installed and lookin shiny. Thanks v. much
