AUDIO WON'T SHOW UP ON FCP7 (mntn lion)
Milton Ginsberg
on Jun 22, 2013 at 7:28:17 pm
importing quicktime film clip into fcp7 (via mpeg stream, handbrake off of dvd off of tv)
audio wont import with it
though it WILL import into fcpx, qwicktime player ???
How do I do solve this?
Milton Ginsberg
Re: AUDIO WON'T SHOW UP ON FCP7 (mntn lion)
on Jun 22, 2013 at 8:05:38 pm
sorry, SNOW LEOPARD !
afraid to move on because of fcp7
Shane Ross
on Jun 23, 2013 at 6:25:12 am
Converted to what format? And what compression type and frequency is the audio?
Shane
Little Frog Post
Rafael Amador
on Jun 23, 2013 at 11:16:55 am
[Milton Ginsberg] "importing quicktime film clip into fcp7 (via mpeg stream, handbrake off of dvd off of tv)audio wont import with it "
Open the file in QT or MPGStreamclip and see if the audio is MP2 (MPG-1/Layer2).
In that case FC can not read the audio.
Convert the DVD files to something with PCM audio (48Khz, 16 bits).
rafael
Milton Ginsberg
on Jun 23, 2013 at 2:38:06 pm
Thank you for trying to help, guys...
This is what MPEGStream shows me the characteristics are
which I want
and which I can't import into fcp7
Video Tracks:
Apple ProRes 422, 1280 × 720, 29.97 fps, 61.45 Mbps
Audio Tracks:
16-bit Big Endian stereo, 48 kHz, 1.54 Mbps
(no problem fcpx, but if i make an .mov in fcpx and import into fcp7
still won't read audio???)
Rafael Amador
on Jun 23, 2013 at 3:05:25 pm
[Milton Ginsberg] "Video Tracks:
Audio Tracks:
16-bit Big Endian stereo, 48 kHz, 1.54 Mbps"
That seems OK.
[Milton Ginsberg] "(no problem fcpx, but if i make an .mov in fcpx and import into fcp7
still won't read audio???)"
The only way to know it, is to try.
Export a short clip and see what hapens.
rafael
Mark Suszko
on Jun 24, 2013 at 2:00:44 pm
Dumb question, but can you post a screenshot of your sequence settings and video/audio settings?
Milton Ginsberg
on Jun 24, 2013 at 2:39:38 pm
Thanks everyone, problem solved. I took the audio into compressor and made
a quicktime audio file out of it and laid it in timeline. But thanks for all your interest. COW far and away the best place for editing help.
