Integrating DVD clips into Documentary
Milton Ginsberg
on Jun 18, 2013 at 7:10:07 pm
Iā€™m making a doc combining public domain movies off dvds with live action (avchd).
Of course I need optimum quality so please be so kind as to comment on my flowchart:
Timeline in FCP7: prores 422 / 1920x1080 / 23.98 fps
Using HANDBRAKE off dvd > High Qual H264
Then MPEG Streamclip ā€” Prores 422 @ 108i
(rather than 720p or unscaled ā€” Do I want to de-interlace?)
Then restoring image to original shape using motion in FCP7.
(Also, using FCPX to convert out of camera AVCHD material to MOV. > FCP7)
Thank you, mmg
Mark Suszko
Re: Integrating DVD clips into Documentary
on Jun 18, 2013 at 7:51:21 pm
Streamclip already does what Handbrake does, doesn't it? Why are you converting twice?
Milton Ginsberg
on Jun 18, 2013 at 8:13:39 pm
Streamclip converts some of these files, but not all.
Shane Ross
on Jun 18, 2013 at 9:12:43 pm
Use COmpressor to upscale and convert the files you rip as H.264s. Turn on the FRAME CONTROLS and set them to BEST. COnvert the frame rate there too. I had to do this a few times in my career...two projects in the last month alone.
Shane
Little Frog Post
Milton Ginsberg
on Jun 19, 2013 at 2:25:34 pm
Thanks Shane, I'll give it a try.
What frame rate do you recommend, 23.98 or 29.
from FCP7 timeline on down?
