Frame Rate Problems
Jim Sandsten
Frame Rate Problems
on Jun 14, 2013 at 7:37:38 pm
Hey guys, i've recorded some material on two GoPro HD Hero3. Sadly I forgot to synq the framerates to the same.
Now when I import the Gopro files, one is 29,97 and the other is 25 FPS
When i imported these two into FCP 7 one appear much longer then the other, but I started and stopped the recordings at exactly the same time
I want of course these two to match in lenght how do i correct my mistake?
Sorry if my english is bad, im from sweden so.
Thanks! :) have a nice day!
Andrew Rendell
Re: Frame Rate Problems
on Jun 15, 2013 at 6:19:15 am
You have to choose the frame rate for the sequence and convert the file that's different to match it.
So assuming that you want to stick to the broadcast frame rate in Sweden, that's 25fps, you should use 25fps for the sequence setting and convert the 29.97fps recording to 25fps. You can do that conversion with Compressor before importing and editing with it, or you can import it without changing it and use a plugin effect like Nattress to convert within FCP.
