using ecamm recorder Skype in FCP
tonya easbey
on Jun 14, 2013 at 1:04:07 am
We're having a problem using clips recorded from Skype via Ecamm Recorder, converted to apple proress422, then brought into fcp.
We getting "General Error" once in FCP and rendered.
For some reason the frame rate of clips came in at 8fps, 10fps and another at 14.99 fps, and the original quicktime .movs at 10fps.
Is there a better conversion via compressor or do I need to change settings in Ecamm recorder? The program doesn't give numerical "video rate"choices, just slow/medium/fast.
For our test we did the first clip (that came into FCP as 8fps) with remote record only and the second clip (that came in at 14.99 fps) as advanced multi-track. We did get one clip to run without error by compressing to apple prores422 for progressive, but video still jumps too much.
I just know we can make this work, but how?
Tonya Easbey
AdagioProductionsMT.com
Granada Hills, CA 91344
tonya@adagioproductionsmt.com
Michael Gissing
Re: using ecamm recorder Skype in FCP
on Jun 14, 2013 at 1:50:17 am
FCP only understands certain standard frame rates. You will have to convert the footage in Compressor so that it has a standard frame rate. Preferably the same frame rate as your edit sequence, cause FCP hates different frame rates, even when they are standards like 23.98, 24, 25, 29.97
tonya easbey
on Jun 16, 2013 at 9:46:40 pm
thanks for the reply.
so how do we change the frame rate in compressor without making the voices sound like Mickey Mouse?
Tonya Easbey
