Final Cut Pro Exporting difficulties
Jennifer Black
on Jun 10, 2013 at 1:36:08 am
Hi, I am trying to export a 8 minute project file from Final Cut Pro and continually get a window popping up QuikTime Error: -50. I have tried many different ways with no luck. any ideas? thanks...
Jamison Lee
Re: Final Cut Pro Exporting difficulties
on Jun 10, 2013 at 1:54:57 am
provide more info - sequence settings, what type of footage, what type of export...
Jennifer Black
on Jun 10, 2013 at 2:00:19 am
Hi, here are some more details. I have tried numerous ways, web hosting, normal export via Quicktime movie to get a different result. Here is one when I tried to export the file to H-264 - The share operation Export File has failed the operation could not be completed because an error occurred when creating frame 314 (error-1). I would be happy for any suggestions...Thanks...
Jennifer Black
on Jun 10, 2013 at 2:06:32 am
Hi, here are some more details. I have tried numerous ways, web hosting, normal export via Quicktime movie to get a different result. Here is one when I tried to export the file to H-264 - The share operation Export File has failed the operation could not be completed because an error occurred when creating frame 314 (error-1). The footage is normal video fottage and alot of stills, there are quite a few transitions amoungst the stills. Could that cause the problem.
Jamison Lee
on Jun 10, 2013 at 2:43:41 am
I'm a bit confused but stills can cause problems, especially if they are large or a format that
FCP doesn't support. Can you render the timeline at all? Try exporting a full resolution quicktime
(no conversion) and use compressor or another utility to do the web compression. Get it "mixed down"
to a single file, a master.
Jennifer Black
on Jun 10, 2013 at 10:23:36 am
Hi, thank you for your response. In the end I duplicated the file and tried to export the new one, that one worked! So strange...the finished product is a bit jumpy tho, especially through the transitions. An suggestions? Does Compressor do a better job?
