Can I look at a clip and see which sequences it is in?
Noam Osband
on Jun 6, 2013 at 5:03:33 pm
I have a huge project file, with a ton of clips and many sequences. I want to search to see if a particular clip is used in any sequences. How can I do that?
Shane Ross
Re: Can I look at a clip and see which sequences it is in?
on Jun 6, 2013 at 5:33:37 pm
Open a sequence, press CMD-F..type in the name of the clip. Repeat in all the other sequences.
Shane
Little Frog Post
Noam Osband
on Jun 6, 2013 at 5:40:15 pm
can i do this without opening sequences? i have a ton of sequences and am wondering if i can search without needing to open them.
Shane Ross
on Jun 6, 2013 at 5:41:44 pm
No...you need to open them.
Or you can highlight them, export them as XML, import them into an application called Sequence Clip Reporter (intelligentassistance.com) and search the file it makes. But the first option is free, and faster.
Shane
Little Frog Post
