P2 log and transfer fail to load some rushes
Rashid Zahiruddin
on Jun 6, 2013 at 4:32:56 pm
I've search in the forum but couldn't find any solution. Please help. I've received a hard disk with "CONTENTS" folder and other subfolder for P2 in it. I use the log and transfer (FCP 7.0.3) to ingest these rushes.
I check the "VIDEO" subfolder and there are 41 rushes altogether. But when this folder loaded in log and transfer window, only 38 rushes manage to load. 3 rushes fail to load. Any ideas why this happen?
Cheers
Shane Ross
Re: P2 log and transfer fail to load some rushes
on Jun 6, 2013 at 5:29:37 pm
SPANNED clips. P2 cards have a 4GB file size limit. Any footage that goes beyond that will break up into multiple files. But FCP will stitch them together when you import.
Shane
Little Frog Post
Rashid Zahiruddin
on Jun 6, 2013 at 5:43:57 pm
Thank you Shane for the clarification.
Appreciate the help.
Cheers
