Trouble burning SD DVD from FCPX
Katie Korgan
on May 30, 2013 at 10:20:25 pm
I have a 1-hour video created in FCPX that needs to play on a SD television via DVD. It's set up at 4:3 aspect ratio and includes both video with sound and still images.
I want to export a file that will burn to a DVD via Toast Titanium without pixelation. I've been exporting to Compressor but at that point I'm stumped; the setting "MPEG-2 for DVD" doesn't export audio, and when I export an AAC file to go with it, they don't combine in Toast and are two different files.
The ProRes files are too big to fit on a DVD-R.
What should I be exporting from Compressor in order to get a high quality video that I can then drop into Toast to burn? I realize SD won't be as high of quality as HD.
HELP! Thanks.
