How to get .MTS files into FCP 6 from a hard drive (the card has already been erased)
andy tolbert
on May 28, 2013 at 1:15:28 pm
Someone mentioned log and transfer to me but I believe that only works with a reader (right?)and the card has already been wiped.
Do i need to get software? Toast v 11? something like that? I know streamclip won't do it. Need to get these in ASAP.
AT
Eric Strand
Re: How to get .MTS files into FCP 6 from a hard drive (the card has already been erased)
on May 28, 2013 at 3:27:40 pm
Do you have the full structure of the card intact on the drive? If so you can still use L&T, just have to tell it to look on the drive. If not you can use ClipWrap, it rewraps or transcodes the clip, depending on what you choose.
http://www.divergentmedia.com/clipwrap
andy tolbert
on May 28, 2013 at 5:13:14 pm
Thanks! No they just copied the .mts files but I will let them know for the future...and thanks for the clipwrap 411!
Eric Strand
on May 28, 2013 at 5:54:11 pm
You're welcome.
Michael Gissing
on May 28, 2013 at 11:08:04 pm
You should always convert from the hard drive backup, not the cards when using L&T. If you have to recapture for any reason, it will be looking for the card, not the backup. So do the original L&T from that backup.
I always save the total card structure on two separate drives (both RAID 5) and do the L&T before erasing cards.
andy tolbert
on May 29, 2013 at 12:15:40 am
Thanks so much. You and Eric have really helped me out here.
AT
