Problem with FCP Import from Soundtrack Pro
Chris Sobchack
on May 25, 2013 at 7:56:32 pm
Hello all at CreativeCow FCP Forum
I'm an amateur editor running a MacBook Pro 2.7 GHz Intel Core i7 qirh 8 GB RAM.
I've run into a really weird glitch...
I send a project from FCP 7.0.3 as a multitrack project to Soundtrack Pro 3.01.
This works perfectly. I make my edits and changes. if I roundtrip at this point everything drops into place perfectly.
However, if I make changes in FCP and then resend and conform within SP (which works perfectly and is in sync within SP) when export back into FCP for some reason the new sequence FCP creates reverts to the unchanged updated Video and Audio (with the audio turned off and the Aiff mix in place as per normal)!
Anybody know what the heck is going on?
WTF?
Cheers for any guru like advice you have!
