XML Export strips line breaks from Outline Text clips
Marty Kent
on May 24, 2013 at 1:50:50 am
I have a sequence that includes a bunch of Outline Text clips. When I export an XML for the sequence, the line breaks are stripped from the text contents. (So, if I export the XML and then import it right back in, what I get is quite different from the original.)
Does anyone know a way around this?
Alternatively, if you can suggest a way to change the font size for each of 950 clips, without exporting an XML, processing it and then loading it back in, I'd be very happy to hear about that.
Thanks to all
Kent's Heuristic: Look for it first where you'd most like to find it.
