color correcting on iMac?
Jason O'Hara
on May 23, 2013 at 12:50:36 am
I am doing color correction on an iMac, is this a bad idea?
Shane Ross
Re: color correcting on iMac?
on May 23, 2013 at 12:53:21 am
For broadcast? Web? DVD?
Shane
Little Frog Post
Jason O'Hara
on May 23, 2013 at 2:26:40 am
thanks, for digital projection in theatre
Shane Ross
on May 23, 2013 at 4:49:37 am
Then you need to get a Thunderbolt out device...Blackmagic UltraStudio Mini Monitor is $145...connect that to a decent HDTV...and you should be good to go.
Shane
Little Frog Post
Nicholaus Mtawa
on Oct 26, 2013 at 8:06:32 am
Sorry shane can you Explain to me what do i need to have in order to do high quality color correction in a simple Budget regarding tools and Software. Current i own only my Camera PMW ex280 and iMac 21"
this image has impressed me much.
Thank you again
Nicholaus Mtawa
Deepnic Media
Shane Ross
on Oct 26, 2013 at 6:08:18 pm
Does your iMac have Thunderbolt?
Shane
Little Frog Post
Nicholaus Mtawa
on Oct 26, 2013 at 7:05:18 pm
No, it has firewire port, Display Port and USB Ports
Nicholaus Mtawa
Shane Ross
on Oct 26, 2013 at 11:12:21 pm
Then no, alas. BlackMagic Decklink has USB portion, but none of them are for the Mac, PC only. And FireWire options are no longer made.
Shane
Little Frog Post
Nicholaus Mtawa
on Oct 27, 2013 at 7:44:07 am
.....and then, what should i do and i want to do coloring on my videos like professional. Any suggestion sir!!
Shane Ross
on Oct 27, 2013 at 5:32:14 pm
Buy a computer with Thunderbolt, then get something like the AJA T-TAP or Decklink Extreme Mini Monitor...and a good HDTV.
Shane
Little Frog Post
Nicholaus Mtawa
on Oct 28, 2013 at 10:15:33 am
Thank you shane, hoping to work on that. if anything wrong i'll get back to you for help!
Regards,
Nicholaus Mtawa
