Need to turn Alexa slow-mo footage into High Frame Rate playback material
Joewi Verhoeven
on May 20, 2013 at 6:46:26 am
Hello everybody,
I'm doing my thesis on High Frame Rate cinema and I shot some 60fps/48fps test footage with the Alexa, unfortunately the timebase of the camera couldn't go higher than 30fps so I kept it at 24fps, which turns it into slow-motion footage.
I need to turn the footage back into the original speeds in post, so real 60fps when playing back.
I'm not sure if this can be done in FCP or if I need any other specific software for this? I have AE to my disposal.
The only method I can think of now is creating a 60fps project and speeding up the HFR material in FCP, but that seems to be quite an inadequate way of doing it. Any help on this would be much appreciated.
Much thanks.
Joewi
Shane Ross
Re: Need to turn Alexa slow-mo footage into High Frame Rate playback material
on May 20, 2013 at 5:49:41 pm
[Joewi Verhoeven] "The only method I can think of now is creating a 60fps project and speeding up the HFR material in FCP, but that seems to be quite an inadequate way of doing it. Any help on this would be much appreciated."
That's what you do. How is that antiquated? How ELSE would you do it?
Shane
Little Frog Post
