Problems Logging XF files with a Changed File Structure into FInal Cut Pro 7
james kendi
on May 19, 2013 at 4:25:18 pm
While copying XF files from a Canon C300 I ignorantly altered the file structure and didn't copy the folder named "Content". Instead I bypassed the "Content Folder" and copied and saved the "Clips" Folder with all the original footage.
Can anyone recommend what to do and how I can get these files to Log and Transfer?
There must be a way!!!!
HIghly Appreciated!
James
Shane Ross
Re: Problems Logging XF files with a Changed File Structure into FInal Cut Pro 7
on May 19, 2013 at 7:59:26 pm
There isn't. Without the full file structure and supporting files, log and transfer is useless.
The only solution now is third party MXF readers. I highly recommend CALIBRATED MXF IMPORT:
http://www.calibratedsoftware.com/MXFImport_Mac.asp
Shane
Little Frog Post
