FCP 7 Smoothcam filter turning progressive footage into interlaced
Ben Neufeld
on May 15, 2013 at 3:32:23 pm
Hey, not a huge problem as I know that if I want to get serious about stabilization Motion (and I imagine After Effects) has a much more sophisticated stabilization filter, but this is just a very annoying problem because I had been using the smoothcam filter on this same footage with no ill effects until recently...
Basically I have 29.97 1440 x 1080 60i footage that was deinterlaced and converted to 29.97p using Mpeg Streamclip. Now as I apply a smoothcam filter to some of the footage in FCP 7 it appears to get reinterlaced (and poorly) i.e. edges of objects in footage are riddled with horizontal lines. Oddly, this seems to only be a byproduct of the Translation Smooth slider in the SmoothCam settings, when it's brought to 0 the distortion disappears. Any ideas?
Also, distortion only appears after render.
Ben
