35mm transfer to DVcam...capture settings?
Woody Brubaker
on May 7, 2013 at 4:12:59 am
I've been handed a DVCam tape of a 35mm film transfer. I have no idea what to capture it at. Is there a suggest setting I should do this at or is the only setting what I suspect it is (DV NTSC)?
Shane Ross
Re: 35mm transfer to DVcam...capture settings?
on May 7, 2013 at 5:20:53 am
Your suspicions are correct...DV/NTSC.
Shane
Little Frog Post
Woody Brubaker
on May 7, 2013 at 6:29:22 am
Is there any sort of pulldown I should be doing to get it back to 24fps (as I assume the original film was) or should I just run it through compressor after?
Shane Ross
on May 7, 2013 at 4:25:30 pm
Use Cinema Tools after you capture to do the pulldown. You'll have to test the 4 options provided to see what works best.
35mm to DV...that's a HUGE quality loss. Plan on onlining this in HD in the future? HOW? Do you have an ALE or FLEX file that goes with this tape? Is it a dub of an HD tape? Or is DV the final (shudder) destination?
Shane
Little Frog Post
Woody Brubaker
on May 7, 2013 at 6:21:23 pm
It's a DV tape that's fairly old, transferred from 35mm long ago for purposes I'm not quite sure. It's all I've got to work with at the moment, though, yeah, in an ideal world, I'd love to go back and have the stuff retransferred at HD quality. For now, though, I'm kinda stuck working with the DVcam tapes.
