interlacing
Stephen Franciosa
interlacing
on May 3, 2013 at 3:29:30 pm
I have this video footage shot on mini dv at 29.97 which im editing however i cant seem to understand why I am having a weird interlace issue. Every frame has this weird interlace. if i change the field dominance to NONE or just de-interlace the clip, it cleans it up but I still feel like its not as clean as it should be. Am i bugging out after looking at HD footage for so long or am I missing something.
jerry wise
Re: interlacing
on May 3, 2013 at 5:03:25 pm
NTSC interlaced should look this way on a still frame with movement. on a still frame without movement you won't see the interlace.
Nikolas Bäurle
Re: interlacing
on May 3, 2013 at 7:49:06 pm
It really depends for what you need it. If its going to DV Tape to be shown an a SD TV you can leave it as is. Interlace always shows up on computer screens.
For Internet you need to deinterlace.
There's always a loss when deinterlacing. As far as I know FCP Legacy and Premiere simply gets rid of one of the fields.
"Always look on the bright side of life" - Monty Python
Stephen Franciosa
Re: interlacing
on May 3, 2013 at 9:06:11 pm
thanks guys!
