Rendering Avid DNxHD layers in FCP
Andy Lawrence
on May 3, 2013 at 2:39:57 pm
I have 2 clips of avid DNxHD clips in an FCP timeline. The sequence has been conformed to the avid DNxHD clips and will quite happily play each clip back in real time.
The problem occurs when I place one clip ontop of the other, it asks me to render the whole section of the clip. I can't see why it should need to render since its only playing the top clip.
I have tested this with 2 pro res clips and this problem does not happen. Due to the nature of the project, I would rather not have to conform everything to Pro Res
If anyone knows anything about this problem, let me know.
Cheers,
Andy
Shane Ross
Re: Rendering Avid DNxHD layers in FCP
on May 3, 2013 at 5:08:15 pm
The problem is that DNxHD isn't a real time codec FCP works with. It SEEMS like it, but when you do things like you are doing...you see that it doesn't. If you only put one portion of a clip on top of another, razor the portion you want on top...instead of moving the whole clip.
Shane
Little Frog Post
