Is there a way of making a PDF of the bins in FCP 7? In reference to logging rushes
Matthew Groark
on May 3, 2013 at 11:38:52 am
I need to produce a full rushes log, I am doing this as you'd expect in excel. The thing is I have already made a log in the master comment section for the editor in FCP. Its a long task and I feel like I'm doing it twice. The editor said there is a plugin for FCP that allows you to make a pdf of the bins? I have found Final Print which allows you to print out the bin but doesn't let you save a file of any format.
Is their any software that I can use to save time?
Any help on this would be greatly appreciated
Matt
Neil Patience
Re: Is there a way of making a PDF of the bins in FCP 7? In reference to logging rushes
on May 4, 2013 at 11:31:42 pm
Hi Matthew
Final Print can save a pdf according to the webpage. http://www.digital-heaven.co.uk/finalprint
In OS when the print dialogue box comes up you have the option to save as pdf. Just select that and you can make a pdf very easily. (Button is bottom left)
Here is a screen grab of the pdf file.
best wishes
Neil
http://www.patience.tv
8 Core MacPro, Kona 3, Tangent Wave, Mackie Universal Symphony 6.5 FCP7
i7 2.7 Gig MBP (non retina) 16Gigs Ram Blackmagic Monitor Mini Symphony 6.5 FCP7
Matthew Groark
on May 9, 2013 at 3:13:35 pm
Thanks very much for your help
Thats great
