Fonts look bad after render
Rocco Leone
on Apr 28, 2013 at 1:01:56 am
I am using FCP 4.5 and I am editing a project starting off with a title. The title looks great before render, after render the title looks bad with zagged edges. I am lost after trying a few different things. Any help? I need suggestions. Thanks.
Rafael Amador
Re: Fonts look bad after render
on Apr 28, 2013 at 4:17:13 am
I bet you are editing in a DV sequence.
Try changing the sequence codec by DVCPro50.
Set the Canvas at 100% to see how really looks.
Rafael
Rocco Leone
on Apr 29, 2013 at 2:39:10 am
Rafael, Thank you! Yes, you were right. I was using DV. I changed it to DVCPro50 and once I changed the pixel to square everything looked better after render. I am happy with the results. Better than what I had before. Thanks again!!!!
