Log & Transfer issue
Mark Allen
on Apr 26, 2013 at 12:20:41 pm
Installed FCP7 on my Macbook Pro, Lion OS.In the transfer window the video level on all clips look fine. Once transfered it looks 4 f stops low in both the viewer and on the timeline. But in clip editor it looks fine.
I have uninstalled and reinstalled the software. Still the same.
Help!
Rafael Amador
Re: Log & Transfer issue
on Apr 26, 2013 at 1:51:19 pm
Many of those gamma and color issues are fixed by installing QT.7.
Do it if you don't have it done yet.
rafael
Shane Ross
on Apr 26, 2013 at 3:50:10 pm
And note that none of those windows show an accurate representation of the video levels of your footage. Not Log and Transfer, not the Viewer, not the Canvas. L&T is the most wrong....the Viewer is the most accurate. They might be CLOSE to what you see when you export a final...they aren't spot on.
Shane
Little Frog Post
Mark Allen
on Apr 26, 2013 at 5:02:24 pm
thanks for responding shane.
of course you're right about video levels in any of the windows, but the confusing part is the footage from my camera was fine on a six year old mac running the same FCP7. the new laptop is where I'm having the problem. The clips are fine when dumped to a drive and run on AVID.
That's why I'm perplexed.
Mark Allen
on Apr 26, 2013 at 4:58:26 pm
Thanks for responding.
Are you saying Quicktime 7? I'm running 10.1.
Shane Ross
on Apr 26, 2013 at 5:40:18 pm
QT 10.1 is unfinished software and buggy. QT7 is what FCP needs to work right. Find that on the LION installer under OPTIONAL INSTALLS I believe. Or download it from Apple and install and update fully.
Shane
Little Frog Post
