Importing Photoshop File With Text Into FCP X Shows Up As Black
Adam Markon
on Apr 26, 2013 at 12:19:07 am
I'm a novice with Final Cut Pro X, but I've used FCP 7 extensively, so I know that the process of importing .psd files into FCP used to work relatively seamlessly. However, today I was working on a Photoshop file in which I need to animate some text and superimpose it over a video.
I have about 50 text layers, all of them rasterized, and several images, all of which have had their layer styles flattened. I export the .psd file using the Maximize Compatibility option, and when I preview the file on the desktop using Quick Look it displays correctly. However, when I go into FCPX and import the .psd file and put it on the timeline it shows up as completely black.
I have the viewer background set to checkerboard in preferences, and the problem is only when I play back the video. If I scrub over an individual layer it appears as transparent. I've tried placing the .psd file in by itself, I've tried placing it over a solid white background, yet it always shows up the same.
Any help would be appreciated, I'm pretty lost here.
Neil Patience
Re: Importing Photoshop File With Text Into FCP X Shows Up As Black
on Apr 26, 2013 at 6:39:24 am
Hi Adam
You will likely get more responses if you post in the FCP Techniques forum here
http://forums.creativecow.net/fcpxtechnique
This is FCP Legacy - you may get an answer here but more likely over there.
cheers
best wishes
Neil
http://www.patience.tv
8 Core MacPro, Kona 3, Tangent Wave, Mackie Universal Symphony 6.5 FCP7
i7 2.7 Gig MBP (non retina) 16Gigs Ram Blackmagic Monitor Mini Symphony 6.5 FCP7
