Auto distort FCP 7
John Barata
Auto distort FCP 7
on Apr 24, 2013 at 10:11:13 pm
HI,
I am working on a SD widescreen show right now and everytime I import any 16x9 footage FCP automatically does a -33 distort to it to make it anamorphic. Alot of the clips are coming from after effects so it's getting aggravating to have to go into every clip and bring the distortion back to 0. Is there any way to stop FCP from distorting the video on import?
Cheers,
John
Shane Ross
Re: Auto distort FCP 7
on Apr 24, 2013 at 10:21:26 pm
FCP is designed to work with broadcast formats. There is no such thing as an NTSC widescreen 16:9 format...not in broadcast. So FCP makes the footage anamorphic, because that's how you typically deliver widescreen SD.
No way to change that upon import, but you can copy one clip and paste the attributes (distort) to the other clips.
Shane
Little Frog Post
Rafael Amador
on Apr 25, 2013 at 1:56:16 am
The footage get that distortion because is interpreted as Anamorphic by FC, so you must to go to the Browser and make sure that the 4x3 stuff is not checked on the "Anamorphic" column.
rafael
