Creating a HD DVD using type 5 DVD.
Kevin Blum
on Apr 24, 2013 at 8:17:45 pm
I'm attempting to burn an HD DVD in DVD Studio Pro 4 using Ken Stones tutorial. I used Compressor to make my H.264 master (multi-pass, 1920x1080). I set DVD Studio Pro to HD DVD. But when I try to drop my H.264 master into the template, I get an error reading saying the format is not supported.
Has anyone successfully done this?
http://www.kenstone.net/fcp_homepage/hd_dvds_on_sd_dvds_young.html
Shane Ross
Re: Creating a HD DVD using type 5 DVD.
on Apr 24, 2013 at 8:36:15 pm
There are HD DVD presets in Compressor...use those.
And you know that ONLY Macs and Toshiba HD DVD players will play these back, right? HD DVD is a dead format...lost to BluRay.
Shane
Little Frog Post
Shane Ross
on Apr 24, 2013 at 8:37:46 pm
You can make BluRay disks with regular DVDs and the DVD burner. You just need to use the SHARE option to do that. And I think you are limited to a running time of 10-15 min.
Shane
Little Frog Post
Kevin Blum
on Apr 24, 2013 at 10:15:30 pm
How do I do this? Using DVD SP?
Shane Ross
on Apr 24, 2013 at 10:16:56 pm
Make BluRay? You use the SHARE option directly from FCP. BluRay is an option.
Shane
Little Frog Post
Kevin Blum
on Apr 25, 2013 at 6:28:02 pm
Thanks Shane. Never knew you could do this.
Mark Suszko
on Apr 25, 2013 at 7:52:28 pm
It's not ideal, (share function off the timeline) but I'm grateful for it all the same: if you make PSA's and commercials or news clip VNR packages, that's a long enough duration to distribute a high def product via the BluRay instead of an FTP or more expensive tape process. And the BD makes a great shelf archive.
Bret Williams
on Apr 27, 2013 at 1:52:20 am
It's not really a bluray. It's an AVCHD at about 1/3rd the bit rate of regular bluray. But they look great. If you just make a file you can take it over to toast and make basic menus.
