Exporting from FCP for editing in Avid
Patrick Murphy
on Apr 23, 2013 at 5:34:38 pm
Hi there,
If someone could help with this i would be eternally grateful!
I have filmed a job today on Sony EX3, i need to FTP the footage to Russia.
My plan was to bring the footage in to FCP 7 to trim some clips and delete those that were dud takes, and then export fro FCP to FTP it. Once in Russia they plan to edit it in Avid.
These are the settings they have requested
Audio codec MPEG AAC
Frequency sampling 48000 Hz
Video codec H264-MPEG 4 AVC
1920x1080
frame rate 25
Planar 4:2:0 YUV
I am having trouble though exporting from FCP and keeping 2 audio tracks which i need as one is natural sound whereas the other is a personal mic.
Can anyone help? THey are waiting on the footage in russia at the moment!
Paddy
Shane Ross
Re: Exporting from FCP for editing in Avid
on Apr 23, 2013 at 5:56:02 pm
The only way to have the audio pass-through while compressing the video is to take the source clips into Compressor. Set the video compression in there, and set audio to Passthrough. This means that you'll have to Media manage the sequence with selects to COPY...make new copies...with no handles. And then take the resulting files into Compressor, apply the settings, and let it go.
Shane
Little Frog Post
Patrick Murphy
on Apr 23, 2013 at 6:15:47 pm
Hi Shane,
Thanks for this. I have just tried to change the audio output sequence settings to dual mono, would this not keep the two tracks separate during export?
I am not great with Compressor, i seem to only have MPEG 1 and MPEG 2 settings in my settings options....
Paddy
Shane Ross
on Apr 23, 2013 at 6:32:04 pm
No...H.264 is there. You can search for that in the search area for the compression...or look under the Quicktime 7 Streaming, or QT 7 download. That's where H.264 is. Audio...they want it compressed to AAC, and still dual mono separate? So you can't do passthrough then.
And yes, you'd export dual mono. Perhaps that will keep the audio tracks separate.
Shane
Little Frog Post
Patrick Murphy
on Apr 23, 2013 at 6:41:20 pm
Sorry no that was me talking about Dual mono they just gave me these settings
1920x1080
frame rate 25
Planar 4:2:0 YUV
But i need to send them 2 audio tracks as one is natural sound and the other is mic sound.
Is ACC compressed to just one track then?
Apologies if thats a dumb question?!
Thank you again
Paddy
Shane Ross
on Apr 23, 2013 at 7:02:06 pm
I don't know. I haven't done it before. YOu'll have to test.
Shane
Little Frog Post
Patrick Murphy
on Apr 23, 2013 at 7:06:13 pm
Ok thanks Shane,
I'll do some tests now
THank you again fro your help.
Paddy
Nick Meyers
on Apr 23, 2013 at 11:13:10 pm
if you media manage as Shane suggests, then the sequence audio outputs are completely irrelevant.
it's odd that you are being asked to convert the media to non-editable formats like H264 and AAC audio.
i guess they will re-transcode it on the other end?
if your audio is 2 tracks only, then i think that you need to make it stereo and convert it as stereo,
than you have a chance of keeping your two tracks separate.
as i say media manager will not change the audio in your files, just trim them of any excess.
so test your conversion to H264 & AAC audio before you go down this path
you CAN change the audio format in FCP by dragging the clips into a timeline,
and making them stereo. (select all, Option L, CHECK YOUR PANNING!)
you can cull the clips in the timeline, too.
then copy/ paste into a new bin, and do a batch export.
Export as QuickTime movies, same settings, USE IN TO OUTS to trim.
(as you are going to convert all these files to H264 you could export as non-self contained. it's a lot faster, but risky in the long run)
this will create new files with STEREO audio, which might convert to AAC better for you.
nick
Bret Williams
on Apr 24, 2013 at 12:32:00 pm
Just about any NLE can edit h264 these days. Just not FCP 7. They may transcode, but when you're ftping ProRes or native files, ftp isn't gonna work. FedEx might be a more viable option in that case.
I wouldn't do dual mono. Just treat it as stereo. You've got 2 tracks. 1 and 2. L and R. If you do dual mono, pan one left and one right. Otherwise youll get them mixed together on the stereo output mixdown to h264.
But if you just treat them as stereo in the first place, track 1 will always come out left, and track 2 right. Make sure you export a stereo h264 and you're good.
Patrick Murphy
on Apr 25, 2013 at 8:12:46 am
NIck,
Thats really kind thank you, after doing what you said and a few tests i managed to get it rich.
THank you again, i really appreciate the help!
Paddy
