FCP blade tool/ ctrl-v command
Nicholas VanVoorthuysen
on Apr 20, 2013 at 4:39:30 pm
Hello,
I have a weird thing happening in a timeline:
Using the shortcut ctrl-v to slice (with NOTHING highlighted/selected), it only cuts the audio. Usually I use it to slice everything at once OR a selection. This is really slowing down my workflow as I'm used to using this command.
So, I'm going through footage and slicing, and I have to double-edit every cut, first the audio, then select the video clip and slice that above it over the audio edit.
anyone had this problem before? Some weird setting I accidentally hit?
Thanks.
Daniel Sametz
Re: FCP blade tool/ ctrl-v command
on Apr 20, 2013 at 5:28:30 pm
To cut you need to use b not v. Doble b cuts everthing in the vertical line not just one clip.
on Apr 21, 2013 at 4:19:57 pm
no, control-V cuts everything that the timeline marker is on without having to click the mouse. I prefer to use control-V over B because it's faster for me to not use the mouse.
My question was answered below though, the issue was that the auto-select was accidentally off for the v1 track. Now I can control-V slice til the cows come home!
Nick Meyers
on Apr 20, 2013 at 10:12:31 pm
"Some weird setting I accidentally hit?"
probably Auto-select is turned off in the relevant video tracks.
thats the tiny dark grey buttons left of the timeline
Command Zero will toggle AUtoselect on all video tracks.
Command 1-8 on specific V tracks
Option Zero, OPtion 1-8 for audio tracks
nick
on Apr 21, 2013 at 4:21:24 pm
Thanks so much, that was the problem, auto-select.
