Is there an alternative to Proxy Mill?
Ned Miller
on Apr 19, 2013 at 11:52:25 pm
I often need to quickly make a copy of the footage I shoot, preferably with visible time code, in a file small enough to send via Yousendit which is under 2GB. This is for clients to choose takes, sound bites or get approval.
Sometimes it takes too long to go through the whole FCP process and then export. I know about Proxy Mill. I was wondering if anyone knows of a similar product?
Ned Miller
Chicago Videographer
http://www.nedmiller.com
www,bizvideo.com
Shane Ross
Re: Is there an alternative to Proxy Mill?
on Apr 19, 2013 at 11:57:43 pm
Compressor. If you make a preset that includes timecode burn. But it does require a bit of compressing knowledge to get all the settings right. That's why I prefer the simplicity of Proxymill.
Shane
Little Frog Post
Neil Patience
on Apr 20, 2013 at 12:18:03 am
Hi Ned
Obviously not specialist software like ProxyMill but this could speed up your workflow depending on the method you currently use.
Shane Ross did a good tutorial on this using FCP7 and Compressor which while not as quick or easy as ProxyMill speeds up the process a good amount.
Worth a look and obviously free.
http://library.creativecow.net/ross_shane/visible-timecode/1
EDIT - Oh well the man himself got there first !
best wishes
Neil
http://www.patience.tv
8 Core MacPro, Kona 3, Tangent Wave, Mackie Universal Symphony 6.5 FCP7
i7 2.7 Gig MBP (non retina) 16Gigs Ram Blackmagic Monitor Mini Symphony 6.5 FCP7
