How is this effect done?
Kevin Blum
on Apr 16, 2013 at 6:35:12 pm
Does anybody know how this effect is done? It looks like it might possibly be an earthquake filter? Not sure how they are creating the RGB split either.
They are throughout this video but the first one is at around 16 seconds.
Neil Patience
Re: How is this effect done?
on Apr 17, 2013 at 1:17:08 pm
Hi
I use Gen Arts Sapphire for this effect - its called Film Roll. However there will be other plug in's that do pretty much the same kind of transition.
Check out Sapphire film roll and it should set you in the right direction for others too.
best wishes
Neil
http://www.patience.tv
8 Core MacPro, Kona 3, Tangent Wave, Mackie Universal Symphony 6.5 FCP7
i7 2.7 Gig MBP (non retina) 16Gigs Ram Blackmagic Monitor Mini Symphony 6.5 FCP7
Ollie Inglis
on Apr 17, 2013 at 3:44:51 pm
Hey man, I think this was done with Video Copilots Twitch Plug in, there is even a tutorial on the site about how to achieve this. In the plug in there is a parameter to change the rgb split aswell,
Hope this helps
Kevin Blum
on Apr 17, 2013 at 6:36:35 pm
That's what I was thinking. I actually have twitch and have used for other things but they use that effect so much in that show they would practically have to edit in After Effects. Thanks!
