PIP Rendering Workflow Issue FCP7
Marie Louise Escoffier
on Apr 16, 2013 at 5:37:45 pm
Hello there, forum!
Looking for help with an issue I can't solve...
Working through multi-cam footage in the timeline, I'm using quick motion scale and centre adjustments to get PIP for easy viewing. This is the same workflow as two others in our studio. The issue is that I have to CONSTANTLY render these effects, while the two other editors I work with DO NOT.
It is a significant disruptor to my workflow - I'm almost entirely hamstrung.
I checked that the clip settings DO match the sequence settings.
What am I missing?
Thanks in advance for the help and guidance.
Shane Ross
Re: PIP Rendering Workflow Issue FCP7
on Apr 16, 2013 at 6:27:04 pm
Set the RT in the timeline (upper left menu in the timeline) and choose UNLIMITED RT.
Shane
Little Frog Post
on Apr 17, 2013 at 12:00:19 am
Thanks Shane!
That seemed to do the trick quite nicely.
I really appreciate it.
