Compressor equivalent to still/freeze duration
Morten Berg
on Apr 16, 2013 at 2:41:16 pm
I'm trying to get my head around this!!
I need to use compressor to import a still sequence and export in ProRess proxy.
I need each still picture to be "duplicated" 3 times, the equivalent to still/freeze duration in Final Cut or Quick Time 7..
help!!! please
Rafael Amador
Re: Compressor equivalent to still/freeze duration
on Apr 16, 2013 at 3:07:08 pm
You haven't chose the best application to manage Sill Sequences, but..I would try this way:
- Set the "Frame Control ON.
- In "Rate Conversion", use "Fast: Nearest Frame" (that will make to repeat the stills without any blending).
- Set Duration 300%.
rafael
Morten Berg
on Apr 16, 2013 at 6:55:09 pm
First try rendered a completely black video, will try again with other codec and settings.
