GoPro Edit strategy
Dimitri Ellerington
GoPro Edit strategy
on Apr 16, 2013 at 11:57:59 am
I have a very short turn around on a job shot entirely on gopro. I've only just started on FCPX and I'm way too slow atm, but I can cut just fine on FCP7. Problem is I think the only fisheye corrector is from crumple pop and that only works on FCPX.
Was wondering, could I use this workflow:
Cut and finish, except for grade &transitions in FCP7
Export cut as prores seq
Import into FCPX
re-establish all the edit points
Then use Fisheye fixer on each bit of the cut I need
Export as prores seq
Import back into FCP7 for grade in magic bullet
What do you think? Would this be stupid? Any suggestions would be great.
thanks for any advice,
Dimitri
