Trashing Prefs Issue
Roy Schneider
on Apr 16, 2013 at 10:04:34 am
Hi All:
I am having problems with playback out of the blue. I decided to trash preferences but when I go to Library- Preferences, I don't see the folder or the files I am supposed to trash. Any advice?
Roy
Roy Schneider
Long Live Da Cow!
Rafael Amador
Re: Trashing Prefs Issue
on Apr 16, 2013 at 10:28:03 am
I think that in the last MacOSx FC preferences are not visible.
Try this free application that will clean the preferences without trashing your favorite settings:
http://www.digitalrebellion.com/prefman/
rafael
Nick Meyers
on Apr 16, 2013 at 3:01:06 pm
also could be you are looking in the wrong Library.
it's your User Library you are after
in the last OS, that was hidden, as Rafael says,
hold Option down in the Finder's GO Menu, and you will see the Library.
when you find the FInal Cut Pro User Data folder, drag it into your side bar,
this won't be the last mite you want to find it
nick
