Green horizonal lines
Lucy McDermott
on Apr 15, 2013 at 11:35:10 pm
I'm getting some horrible green horizonal lines on the cut between 2 clips on an export.
I cant see it when I watch it in FCP, or when I step through frame by frame.
I am thinking this is something to do with fields? But I'm not sure how to fix it - anyone know?
The problem is that the drive of original media has been taken abroad, so I am trying to do it with a series of exports I have. Not the best way I know, but the only way that is possible in the time available.
The 2 clips are both movs, both at Avid DNxHD codec. Both Upper (Odd) Field dominance.
Even when I export them together into one sequence, then take the clip into a new sequence, cut out the frame where the flash is, when I export again, its back! It knows there is some kind of difference between them...
It would understand it if they were different resolutions...
Any ideas guys?
Thanks so much, L
Final Cut 7 on Mac OSX 10.8.2
Shane Ross
Re: Green horizonal lines
on Apr 15, 2013 at 11:44:40 pm
DNxHD isn't an FCP codec. It's an Avid one. I had issues exporting if there was an edit of any kind in the clip. Only solution was to do the edit in Avid, then export the clip for FCP.
I had to bring it into FCP because, at the time, only FCP did multi-channel QT exports (8 embedded audio layers). Avid did not.
Shane
Little Frog Post
