FCP 7 viewer issue after mountain lion upgrade
eamonn collinge
on Apr 11, 2013 at 9:36:12 am
Hi guys I have tried everything I can think of so I am finally turning to the mighty collective power of the cow !
I am running FCP7 on a mac pro with 2x2.4 GHz 6 core intel processors and a Radeon HD 5770 graphics card. OSX 10.8.3.
After upgrading to mountain lion on this new machine I am having issues with the playback of the time line in the viewer window,it no longer plays smoothly it flickers almost imperceptibility on each cut like the image is split for a couple of frames.I have been shooting on a Canon FX300 and encoding to pro res.I also have a black magic card installed and the output to the CRT monitor is smooth.
On slow edits i can live with the issue but I am cutting a fast promo at present and its driving me mad!
Has anyone got the same problem ? any ideas ???????
cheers guys Eamonn
Dave LaRonde
Re: FCP 7 viewer issue after mountain lion upgrade
on Apr 11, 2013 at 6:15:18 pm
In your haste to stay abreast with the latest OS, I fear that you may encounter problems with FCP 7, an application whose most recent update was more than two years ago, before Apple killed it in favor of FCPX.
Is it possible that there may be a conflict between the OS and the application?
Dave LaRonde
Former Sr. Promotion Producer
Warren Eig
on Apr 13, 2013 at 6:01:22 am
No problem here. Did you do a clean install?
Warren Eig
O 310-470-0905
email: warren@babyboompictures.com
website: http://www.babyboompictures.com
REEL: http://www.babyboompictures.com/BabyBoomPictures/Reels.html
eamonn collinge
on Apr 15, 2013 at 3:07:25 pm
Hi guys just to put my mind at ease I did a clean install on Saturday although when i bought the machine i also installed from the original disks.However the problem still persists so Dave may be correct in his analysis. I mean the flicker is marginal I can live with it but like us all we like Our suite to run perfectly
.Curious tho that Warrens viewer playback is smooth could it possibly be something in the sequence settings ?
Anyone else got my symptons
Cheers Eamonn
Warren Eig
on Apr 15, 2013 at 4:24:44 pm
Maybe it is a sequence mismatch. Are you set to dynamic RT, frame rate full? How fast is your storage?
It could be a lot of things.
Warren Eig
O 310-470-0905
