White edges around PNG transparency
Matty Smith
on Apr 4, 2013 at 8:28:25 pm
I'm having a little trouble with some PNG files imported to FCP and haven't been able to find someone with quite the same issue:
Basically, when importing PNG files created in Photoshop, things look good in the viewer (the PNGs have black curved edges, and so I just see black straight into the "black" background of the viewer) but when I get them into the sequence, in the canvas (and subsequent export) I get some weird white around the edges, as if a part of the feathered edges is being read as white rather than part-transparent.
What's the best way to address this? I've tried changing the alpha channel to straight, but that doesn't seem to have done anything. In Photoshop, I tried re-exporting the images with a blank layer on the bottom, and that weirdly seemed to fix it a little but not all the way. Is there something I'm missing? I don't remember having much trouble just exporting a PNG with transparency to FCP before.
Thanks in advance for the help.
Dave LaRonde
Re: White edges around PNG transparency
on Apr 4, 2013 at 9:01:20 pm
If FCP allows it, set FCP to interpret Alpha Channels as Premultiplied. Normally, FCP likes Straight alpha channels, but it can deal with premultiplied files.
Dave LaRonde
Former Sr. Promotion Producer
