Transcode to DVCPRO or ProRes?
Kevin Blum
on Mar 31, 2013 at 1:01:51 am
Hello,
So I footage that is DVCPRO 1080i60 1280x1080. I also have a lot of stock footage that is 1920x1080 but in h.264 that needs to be transcoded. I was wondering if I should transcode to DVCPRO to match my other footage or if should transcode to ProRes to keep it's true 1.0 1920x1080 resolution.
Unfortunately the bulk of the show will be using the footage that needs to be transcoded (h.264).
My delivery format is HDCAM 1080i 59.94.
Rafael Amador
Re: Transcode to DVCPRO or ProRes?
on Mar 31, 2013 at 3:37:50 am
Transcode the H264 stuff to Prores.
The DVCProHd stuff should work OK on the Prores 1920x1080 sequence.
rafael
