Romove noise from air conditioner
Vesko Urukov
on Mar 29, 2013 at 12:13:06 pm
Hello, I have an audio file which has noise and hum from and air conditioner in the room where it was recorded. Can anyone advise me on a good method or filter for removing the noise from the audio file?
Mark Suszko
Re: Romove noise from air conditioner
on Mar 29, 2013 at 2:09:44 pm
Export the audio into Apple Soundtrack Pro. it has a noise removal tool. You sample a section of audio where the only sound is the noise. The effect then uses that "noise print" to create a filter. Read the help files in Soundtrack pro to walk you thru it.
